Is gear swap worth the $$$?
I have 3:42s and the truck seems to stumble a bit under 2500 rpm. I have a W4M tune with torque managment 80% removed. Would a gear swap to 3:90 or 4:10 make a big difference for the money? I only have 6 miles a day on the freeway to drive. The rest of the time I am under 60 mph. 1 or 2 mpg loss on the freeway wouldn't be the end of the world. Opinions? Also, what's the price range for a shop install?
I have gained mpg with the 4.10s and tune for under 65 mph driving. i am not sure how much, but I know that I have. The difference is night and day. You will not need as nearly as much throttle to get moving under normal driving conditions. Down shift points take a little getting use to. I do not believe you can go wrong with either gear choice.
In addition, when passing while in o.d., you will not need to down shift to pass. But, if it does, you will go around who ever pretty damn quickly.
11 Second Truck Club
because the transmissions pulls power from the engine. there was a guy at the track with an 05 gto. i'm not familliar with their gear sizes but it was pretty similar going from 3.42's to 4.10's. his e/t did not change one bit.
Resident Retard
2nd fastest 5.3 ECSB
Unless you drive highway 80% of the time, the 3.42's are too tall. I think GM only put those in there to claim better MPG on the sticker. I changed mine to 3.73 (front and rear for 4x4) and also went to a 1" smaller tire. Handles much better around town, where i do most of my daily driving, yet still gets great milage on the highway, if i can keep my foot out of it!
