gears for 4wd
Old 07-15-2010, 12:26 AM
silverz28camaro's Avatar
I'd bet you could find a LS1 or 6.0 shortblock cheaper then a gear swap front an rear diff will add up unless you set the gears up yourself.
x10 on a good tranny cooler.
Old 07-15-2010, 04:05 PM
dragpac's Avatar
will a 6.0 swap right in and are my heads the same?
Old 07-15-2010, 06:02 PM
white1's Avatar
If its a 6.0 from a GMT900 truck, or I believe an LS2 will work also. Your heads should be the 243 castings, most 6.0s have 317 castings
Old 07-15-2010, 10:09 PM
fredkj3's Avatar
find a 6.0 from a new truck in a junk yard... and use the heads/intake that are on it...
maxspeed05V
11-11-2015 04:20 PM
97aztecgt
08-13-2015 02:11 PM
cams 98 silverado
07-31-2015 07:36 AM
vmaxpro
07-27-2015 10:45 PM
MileHighSierra
07-22-2015 11:19 PM
Quick Reply: gears for 4wd
