GM full size SUV rear-end squeak about to drive me crazy...help!!!
Old 08-01-2006 | 03:57 PM
alan2000T/A's Avatar
10 Second Club
Default GM full size SUV rear-end squeak about to drive me crazy...help!!!
this is my 03 yukon xl I'm referring to.
After new shocks and new boxed lower control arms (from Spohn -same part # as Impala SS) w/ all kinds of greasable fittings -I wasn't able to stop the squeaking.
I've finally narrowed it down to the drive shaft into the rear-end. I've noticed that everytime the torque changes the pinion angle, I get the squeak. It happens when on the gas and the rear-end squats. It happens when braking hard and the rear-end settles. It happens when you are on the gas and going over speed bumps, but does not squeak if you just roll over speed bumps.
I'm at a loss. Any ideas?
Old 08-01-2006 | 04:46 PM
Grumpy5.3's Avatar
sounds like you are having drive shaft clunk. take the drive shaft out and install some special lube in the end of the yoke
Old 08-02-2006 | 08:04 AM
10 Second Club
Thanks. I'll look into that. It does sound like a metallic squeak. I wonder where I can find the lube? I've got some synthetic lubes I might try.
Old 08-03-2006 | 12:28 PM
Yelo's Avatar
Standard moly-based lube is what is reccomended by GM, the actual fix is a brass-plated yoke that the dealer can install...this issue has been creeping up in these trucks since '99 so it's nothing new
Old 08-03-2006 | 09:08 PM
10 Second Club
Thanks! I was waiting on that phrase "brass plated" because I'd heard of some fix before but couldn't remember.
Old 08-07-2006 | 08:47 AM
10 Second Club
Default cheap fix!
Well...after a year and a small amount of cash out the window...I took you guy's advise and pulled the shaft, lubed the yoke, re-installed and all is well! All fixed...done!
Thanks
Old 08-28-2006 | 01:47 PM
10 Second Club
just like folks said, the squawking sound is working itself back. I used the moly-based lube and it worked great for a while.
The squawking and the clunk combined are more than I can stand. I'm taking it to the dealership tomorrow.
Old 08-28-2006 | 01:53 PM
Grumpy5.3's Avatar
TAKE A SMALL RUBBER BOUNCY BALL, CUT IT IN HALF, SLIDE IT IN THE YOLK. THEN LUBE THE SPLINES AGAIN... i WORK AT A DEALER AND WE HAVE DONE THIS SEVERAL TIMES!!!!
Old 08-29-2006 | 08:26 AM
10 Second Club
awesome idea...it's at the dealer today to get checked out. I'll use that if I have to. Thanks!
GXPJAY
02-13-2022 08:15 AM
Stainless Works
04-10-2016 04:34 PM
maxspeed05V
08-12-2015 06:29 PM
FlowmasterMufflers
07-30-2015 05:03 PM
jrplz
07-09-2015 12:07 AM
Quick Reply: GM full size SUV rear-end squeak about to drive me crazy...help!!!
