GMPP Supermatic
Not worth it. Probably have to use the stock stall?
As well as the downtime if it does blow just plain sucks imo. Yeah it gets fixed, but its gone for a week or more, leaves you stranded in the rain etc.
PT's Slowest Truck
Statements like that show that you haven't been building performance cars/trucks very long...you do know that many of the GMPP products are "hecho en Mexico" don't you? I've gotten GM crate engines in the past with loose rod bolts and extra connecting rod caps laying in the oil pan...GM often times doesn't correct their products shortcomings while top notch aftermarket builders do
With that being said, I like the sound of the 3yr/100k warranty, just hope you never have to use it and have your truck torn down numerous times...technicians tend to take short cuts when doing warranty work that doesn't pay well, and when they work on the same vehicle numerous times, things tend to get broken, stripped, left out, and rigged back together. If they same warranty applies if you install it yourself, I'd feel more confident.
I would be right there during and helping with install. The Techs are cool and dont take short cuts. ( The ones that work on my stuff anyway! ) So i feel good about the install.
This one is cool and has gone out of its way to help me with my vehicles, even a tuned lifted 500 horse Duramax With a stack that likes to break G80's LOL!
I would like to hear from TBSS guys who have this trans and see how its holding up for them.
I would love to go drop 2600 on a trans if i was working, I always try to buy whats best. But i really think this trans might just hold up for me.
BTW the Description is as follows from the GMPP catalog "Stands up to high horse power engines, run after run at the drag strip"
So lets keep discussing.....
Tin Foil Hat Wearin' Fool
70s have an input shaft speed sensor but it wont be a problem for his truck, jsut an extra plug int he side of the trans thats not used. And yes it will work for his truck, AWD tcase and 4wd tcase use the same bolt pattern and the output shaft in the trans is the same for both cases.
