Good thing I installed that zipper mod
#32
Raybestos Blues with thick Kolene steels in the 3-4 pack would last 8-9 months for me, like clockwork. The red Altos made it about 3 weeks on the original build, and have never been used again.
This build recieved some sort of "drill mod" to the input drum, supposed to fix the 3-4 clutch issue, and Borg-Warner 3-4 pack.
I'll post up the findings. I think it might be the sunshell or sungear, or a broken band. He used the Alto wide band that I told him specifically NOT to use. I've had my best luck with the normal width carbonite band. I've replaced it with every build(bands are cheap), but it was never worn out.
#33
I had a similar problem with my camaro.Turned out to be a broken lug in the shell.Roger,what kind of line pressure you runing on the down shift and upshift.Im positive that was my main problem when the trans broke.I mean the car would gain like 6-8mph on the 1-2 upshift alone.So I dropped the downshift upshift pressure closer to stock and switch the converter to a much higher stall and the new trans seems to hit the shifts crisp as opposed to a slam.
#35
