Got me a 14 SF 6 lugger
Old 12-30-2008 | 10:07 PM
JakeBrakeIH's Avatar
Default Got me a 14 SF 6 lugger
after buyin a 6.0, turbo and t56 i realize that the stock rear isnt gonna cut it...i wanted to get a 3/4 or 1 ton rear but didnt want to get different axles or anything like that so i remember a kid in high school had an 89 2500 6 lug...so the hunt began and sure enough a local guy about 1/4 up the road from me had one...i traded him a set of wheels and he gave me some cash so now i gotta save and get locker and rear gears for it...
found a lot of good threads with conversion info so i think that this should be a bad swap...found this site in a thread for disc brake conversion, looks like its a home run
http://www.ruffstuffspecialties.com/...cket-p-10.html
keep an eye open for lots of build threads on my truck seeing i have lots of work to do!...
Old 12-30-2008 | 10:24 PM
blue2003ls's Avatar
Nice find. How does everything bolt together? Is there any fab work involved or is it the same width as the NBS?
Old 12-30-2008 | 10:32 PM
from what i remember reading the leaf perches have to be moved in 1.5 inchs or so...
heres a build thread of one...https://www.performancetrucks.net/fo...d.php?t=385553
i just did a quick search and found lots of info...i know that some of the newer trucks came with them factory and are direct bolt in but seeing that are around 1000-1500 bucks if you can find out, i chose this route...havnt decided on rear gears yet, leaning heavy on 4.88s or 4.56s, gotta read some more before i pull the trigger...
Old 12-30-2008 | 10:53 PM
silver-mod-o's Avatar
Hunt&Fisherator
Sounds good bro.... With that trans and a turbo 4.10s should be nice!!!!
Old 12-30-2008 | 11:00 PM
yes 4.10s arnt totally outta the picture, but literally my truck sees about 75%-85% city driving, so im kinda leaning on giving up on some of the performance part if you will to have that nice every dad driveability...but i very well might be buying a small little honda or something to drive everyday so i dont have that problem...if i could keep the same ratio i have now(between my current trans and 3.73s) and the new setup, i think that would be good...just gotta keep diggin up old threads and looking on gear calculators...
Old 12-31-2008 | 10:27 AM
skyhighsami's Avatar
no title here
Are you going to lose the 4wd or try and make it work with the T56?
Old 12-31-2008 | 10:29 AM
no title here
Also keep your eyes out for the gears and carrier out of a Trailblazer SS if the spline count is the same that might be an option. They have the 14 bolt as well.
Old 12-31-2008 | 10:31 AM
na not worth all the effort and extra money...would be nice but much easier to convert to 2wd...
Benlugchev
11-19-2012 07:00 PM
slowsierra
01-27-2006 06:06 PM
Quick Reply: Got me a 14 SF 6 lugger
