got a problem
1 Post
ok....i got my stock **** back in until i figure this **** out.......got my parts infront of me and took some pics.......
part number on detroit....looked it up on summit http://www.summitracing.com/parts/DTL-913A481/
![](http://i123.photobucket.com/albums/o303/87k5boggin/IMG00065.jpg)
bearing i was sent with true trac ac delco part number 942-0095
![](http://i123.photobucket.com/albums/o303/87k5boggin/IMG00058.jpg)
![](http://i123.photobucket.com/albums/o303/87k5boggin/IMG00059.jpg)
delco bearing on left.... bearing from install kit on right....notice size difference
![](http://i123.photobucket.com/albums/o303/87k5boggin/IMG00060.jpg)
bearing from kit fits in housing but inner is to large for tru trac....
![](http://i123.photobucket.com/albums/o303/87k5boggin/IMG00061.jpg)
1 Post
found this on jegs------------All GM 8.5"/8.6"Eaton differentials require special bearings. For 28 spline axles with small bearing bores (race O.D. of 2.89"), usually found on vehicles prior to 1999, bearing LM-102949 and race LM-102911 are required. For 30 spline axles with large bearing bores (race O.D. of 3.06"), usually found on vehicles from 1999 to present, bearing LM-603049 and race LM-603012 are required. Will fit 2005.5-07 SAAB 9-7x
1 Post
ok i am pretty sure i need
bearing LM-603049 it has a 1.6250 bore to fit the trutrac
race LM-603012 it has a 3.0625 outer diameter to fit in my housing
i hope thats all i need?
1 Post
ok so i got these part numbers......
bearing LM-603049
race LM-603012
and the bearings are still wrong.....the inner diameter is to big...it just slides on to the tru trac???? im really getting frustrated......can anyone tell me for sure the right bearings to use or is the tru trac just wrong!
thanks
Caleb
bearing LM-603049
race LM-603012
thanks
Caleb
1 Post
ok im really gettin pissed.....i measured the tru trac and the outer diameter of bearing surface was-1.625 ok now remembering the partnumber on the jegs page-All GM 8.5"/8.6"Eaton differentials require special bearings. For 28 spline axles with small bearing bores (race O.D. of 2.89"), usually found on vehicles prior to 1999, bearing LM-102949 and race LM-102911 are required. For 30 spline axles with large bearing bores (race O.D. of 3.06"), usually found on vehicles from 1999 to present, bearing LM-603049 and race LM-603012 are required. Will fit 2005.5-07 SAAB 9-7x
i got these bearings and the inner diameter is 1.78?????? WTF the part they say to use doesnt even work? so what in the hell is going on?
I need a bearing and race that measures O.D-3.0625 I.D-1.625
I have had zero luck finding that bearings..........
so please what the flying ***** is going on?
thanks
Caleb
thanks
Caleb
1 Post
Ok does anyone know what the correct bearing surface measurment is on the detroit tru trac.....everybearing listed to fit it has a diameter of 1.780, but mine measures 1.625?
