Got some strange noises coming from the truck
i checked to see if the wheel bearings were bad today and they are fine. this weekend i'll drain the fluid in the tcase. i would like to also add i had some new gears installed at a local shop about 2 months before i put the truck down for the turbo build, so they only have about 4 months of road wear on them, i thought that might be the problem if they werent installed right, but if that was the case wouldnt it be roaring all the time instead of when im running around 20-40mph and in the throttle.
i should also add that i get a service 4wd light alot, i need to check the tcase fluid to see if i have metal shavings in it like stated above. how hard is it to rebuild one of these transfer cases, which one is in my truck anyway. its a 00 z71, its an auto tcase.
GreyChevy
07-07-2015 08:57 PM
Breitling
07-06-2015 06:39 PM
