greatest mod i've done yet...addco swaybar
#21
Got mine installed this weekend and all I can say is wooow what a big difference. it made the truck change alot feels tons better. I would tell everyone to get one. The only thing I had to change was the bolts I needed shorter ones 7 inch bolts since I have the 4/6 drop. I am completely happy with the way the truck rides now.
#22
Do the sway bars effect traction? Will it hurt, help or be about the same. I am all for better handling but my traction situation is bad enough I would hate to do this mod and be worse off than I am now.
#26
i'm going to give AddCo a call on this, but...
does anyone know the difference between the 2wd and 4wd sway bar is? is it just that the 4wd has longer end links since 4wds sit higher?
i have a 4wd, but i'm lowered some, so i assume i'd need to just get the 2wd one so it has shorter end links.
#27
#28
I forgot to say that I had lost a nut for my rear driver side end link that I didn't know about until the day after I got sideways. I'm pretty sure that had something to do with it because I have turned harder than that at similar speeds in similar conditions with out loosing traction.
