Grinding nosie from rear diff
First off, int the diff the screw that holds the shaft in between the spider gears, broke and let the shaft fall out and hit the pinion gear while I was driving. I fixed that now there is a grinding noise from the rearend while I am on the gas. It sounds like a brake drum on a lathe. It does do it all the time. I am lost on ideas as to the problem. Any ideas?
No it is a GU6. 3:42 non-Locking. Replacing it is not financially possible at this time. I would like to fix what is wrong until I have the money to replace it all and put in the gears i want and a truetrac.
Mine is making the same noise. Its like a howling noise and is louder when you first give and let off throttle. I am sure it is the pinion bearing and have been qouted near 600 to have it fixed.
