grinding/vibration noise on 02 denali awd
Old 02-15-2012 | 01:02 PM
  #21
RotaryResurrection's Avatar
Originally Posted by Raytx2
I have the same problem on my 2000 Chevy Silverado 4x4 auto track transfer case. The only problem is I created it by installing a Mc Gaughlys 7 inch lift kit. They stated that the drive line angels remain at stock specs with there lift kit but it is not true.Well any way back to your truck the problem is the drive shaft angel. The angels changes when you let off the gas or accelerate. This may be due to worn out u joints, But in your case you replaced them. So the last thing that that is causing your drive line angels to change when you accelerate or decelerate is your motor mounts and transmission mounts. They are probably weak and shift slightly when on the throttel. I Would recomend GM OEM parts they will bring back your drive line angels back to specs.
I appreciate the thought, but...the problem on my truck is fixed already, as stated a couple posts above.
I have not had the time or money to fix my truck so what I did is removed the front drive shaft. You can drive it with the drive shaft removed as I can vouch for that because that is how I am driving my truck every day 50 miles round trip to work. Just make sure you cover up the transfer case output shaft hole with duct tape so dirt and water do not get into the output shaft hole. ASE Master certified mecanic for 15 years and GM dealership experiance 14 years. Ray T.
not on a denali/escalade/SSS you can't. We have the all time awd single speed tcase with the viscous coupler that splits power front/rear. Taking the load off the front drive would most likely damage the viscous coupler. It seems you never get denalis/escalades/silveradoSS' in for drivetrain service at your dealership.
Old 02-15-2012 | 02:16 PM
  #22
Raytx2's Avatar
Registered User
I am glad to see you fixed your truck. I was surfing last night and i did not see your last post. The auto track transfer case works like a full time 4WD.
The only difference is I have a 3 speed transfer case and a front axle disconnect which disconnects the power to the front axle when in 2WD.
A friend of mine has a H3 with full time 4WD and I recently removed his front drive shaft. His H3 never goes off road. With gas prices going up to $3.50 he wanted to gain some fuel economy. He has been driving his H3 with the drive shaft removed for over six months with no problem. I did re-install the drive shaft this weekend for a ski road trip. And he told me the full time 4WD worked like normal. He did tell me that he saw his fuel economy go up with the drive shaft removed. He wants me to remove it again!
Old 02-15-2012 | 02:26 PM
  #23
I'm glad he's had good results. I'm still not sure it's a chance I'd be willing to take....for what, maybe 10 bucks a week in fuel savings at most? Compare that to the possible costs associated with removing the tcase, replacing the viscous coupler, rebuilding and installing. No thanks, not a chance worth justifying IMO.
Old 04-15-2012 | 05:44 PM
  #24
RYNO63SS's Avatar
I was searching front driveshaft when I came up with your thread. I have an 03 2500hd truck, while not awd it it 4wd and all the front end components are turning all the time. No hubs to unlock. Anyway I have been noticing a vibration coming from the front drivers side area Front driveshaft possibly at approx 58-63 mph. I had a little play in my drivers side unit bearing so I changed that to still have my vibration. I then did mor checking and noticed some play where the driveshaft and transfercase meet, and I was wondering if that front output bearing was wearing out. You have been there and done that so I guess I will do some ujoints soon. What brand ujoints did you use? The factory ones on my truck have no grease zerks. I am also searching if someone is making a locking hub conversion for these trucks. Any advice or help is welcome.
Old 05-23-2012 | 04:50 PM
  #25
TURBHOE's Avatar
this is not a viscous coupling case. you drive around with the front shaft out of a viscous coupling case and you will ruin the coupler.
GMCtrk
18
10-06-2015 04:48 PM
turbo6c3
10-05-2015 07:11 PM
2002_Z28_Six_Speed
10-04-2015 02:34 PM
Velocity1
10-02-2015 09:01 AM
02AWDAWSDenali
10-01-2015 06:08 PM
