gut pics of my whiny ass, fluid drippin, clunky ass rear end
How do I change this text
Sadly
I can tell you how those marks got there............
REPLACE YOUR DAMN PINION NUT EVERY TIME YOU REMOVE IT !!!!!!!!!!!!!!!!
BTW I'm still running this carrier........
Originally Posted by Wilde Racing
Sadly
put some heavier fluid in there last night to help with the howling. 70/140 is what it was i think. no synthetic or posi additive since i wont be romping on it as much as usual lol. it did help a little. other than the chewing of my carrier and a good amount of sludge on the magnet everything looked "together" no cracks in the ring or pinion that i could see, the carrier has no cracks....it really drives fine once you get past that giant POP when going from reverse to drive im not afraid to take it another couple thousand but i dont plan on it
im going crazy trying to figure out if i want to stay with the 3.73's or go to the 4.10's....detroit tru-track will complement either gear.
did you replace your crush sleave when you had the gears done?
Looks like your pinion nut is coming/or is loose, and it's making the pinion "walk" out. It's making a new wear patteren on the gears, that's what's making the howling noise. That clunk that you're hearing is your pinion moving backwards when it goes into reverse.
If you keep driving it, you're going to trash your bearings.
It's not torqued, it has a "crush sleeve", the crush sleeve it what is used to take up the differents between the pinion bearings. Of course crushing the sleeve is not very easy, (you'll find out once it's replaced)
You could. replace the sleeve, front seal, and nut, but all that metal will take out EVERY bearing in the rear-end, rather quickly too...
With a new crush sleeve, seal and NUT. you would tighten the pinion nut down until you have a turning torque of 10-15 in.lbs (used bearings) or 20-24in.lbs (new bearings)
Use a dail in.lbs toque wrench and see how much torque is required to spin the pinion gear WITH OUT THE DIFF CARRIER installed.
well in that case, pull your drive shaft and tighten that pinion nut back down, and start saving for the repairs......
The carrier will be o.k, You just cut the fuse a bit shorter on that time bomb. All the bearings will have to be replaced as well as the gears, of course.....
yeah i have no clue what you just said lol. ive never had the rear end apart to see exactly how all the parts fit together. ill just drive the POS the way it is until i get the change to pay a pro to fix it.
ahhh don't do that, you might be able to save the gears
Stewart...somethings going to snap in that thing soon - and you don't want your truck breaking down in front of your mistress's house, that's hard to explain to the girlfriend
does anyone know how much a new carrier will cost me? if im guna do it i want to do it once and do it right. i wont be half assing the rear end or transmission when it breaks.
hey man, I had a guy come in here and he put in his own Differential, and he forgot to crush his Crush Sleeve...and it looked alot like that. When you took it back out...was the crush sleever crushed?
