Guy's with clamped springs come in...
Fellas when you clamped your overload in front of tire for wheel hop did it raise or lower your truck or affect pinion angle much? I searched and never got clear answer.
11 Second Hall Moniter
If you've removed the overload leaf, you'll get different results than you will if you still have the overload leaf.
If the OL is gone, clamping the springs will not change ride height or pinion angle very much at all.
But if you clamp the spring pack to the OL leaf, the pinion angle will change, and the ride height will lower in the rear, by about an inch.
formerly b4vwannabe (2/4/2012)
I think I got at least 1/2" drop when I clamped mine. Took em off before I did the flip/notch. Can't speak on pinion angle or wheelhop as I took them off before I changed gears. I had 3.23s so no problems with traction until I changed over to 4.10s
lxcoupe
07-21-2015 02:12 AM
