Guys in cold climates...whats your trans temps?
PT's Slowest Truck
It doesn't take too long (10-15 minutes) for my trans to be above 120 degrees. In the winter, it usually runs around 135-140 degrees. I have the 40K cooler also, but without the external cold-weather bypass piece of crap.
BTW, that's the same operating temps(135-140) that it runs in the summer time.
What I'm trying to show is that my transmission runs the same normal temps in the winter that it does in the summer. Just like my engine coolant temps.
J/K...and the pic of the trucool box that you posted shows that the external cold weather bypass is just a gimmick when paired with this cooler
Even my bone stock 4L60-E when it is hot out runs about 140-150
When it is below 10-20 degrees mine runs about 115-120 going up and down mountains all day with no problems, as long as the temp is above 100 degrees the TCC should have no problem applying
mines right around 140 degrees at 40 outside cruising on the highway today and when i hit a traffic jam, shot up to 190. this was all in sport mode tuned before the 6 inch lift with 35's and with stock gears.
iat was 19* while moving right before i stopped to take the pic, and compass said 14* out..
no converter with stock cooler
15-20min ride home with slight stop and go except for the last 3-4miles being highway=lock up (which happens at 75* on the dot)
this is with at least 10 if not 15min of warm up time and some heat (40*) probably still barely in it from lunch time 4hrs earlier
moral of the story you guys in warmer places concerned about 130* temps have nothing to worry about imo..
1987cut
07-12-2015 09:59 PM
Nimoryan
07-05-2015 03:50 PM
