Hangars or leafsprings?
Old 11-06-2005 | 04:53 PM
speed01rcr's Avatar
Unhappy Hangars or leafsprings?
Hey guys,
I have a 04' silverado 1500 reg cab, and want a 4" drop in the back. Which do yall reccomend, leaf springs or hangars and shackles?
I can't decide, its making me sick.
Old 11-06-2005 | 04:55 PM
BadAssChevy327's Avatar
hangers and shackles give u the same ride , and towing abilites . leafs give u better handleing besides just sitting lower , but also cuts your towing abilities in half . so its your choice
Old 11-06-2005 | 05:21 PM
speed01rcr's Avatar
how do leafs improve handling?
Old 11-06-2005 | 05:29 PM
04BlackSilverado's Avatar
They are stiffer so wont lean as much in coners. And if you add a rear sway bar it will handle like its on rails!!
Old 11-06-2005 | 06:20 PM
99Silver6.0's Avatar
Leafs are nice. Handling improved alot, no more lean. Although I did sways too. With good shocks it wont ride too bad.
Old 11-06-2005 | 06:43 PM
speed01rcr's Avatar
Seems like changing the leafs would make the ride less stiff since they are not as strong as the oem. "also cuts your towing abilities in half ".
Old 11-06-2005 | 07:00 PM
No no no. New leafs will make the ride stiffer.
Old 11-06-2005 | 07:13 PM
Gran Patron's Avatar
I think both will give you what you want and are both good but I preffer the Hanger&Shackle combo!
Old 11-06-2005 | 07:51 PM
ya there dearched more then stock ones and lot stiffer . and yes it cuts your towing abilites in half . so no more 6,000 pounds and 600 tongue weight , maybe 3,000 and 300 understand
Old 11-06-2005 | 09:52 PM
StrokerAce03's Avatar
Leaves would be easier to install but because of the towing capacity difference I'd go with the shackle/hanger combo. I got shackles with spring clamps right now and I'm gonna get some hangers one day when I get the cash/time to do it. It mainly depends on what you want to do with the truck and how you want it to handle.
Quick Reply: Hangars or leafsprings?
