Hanger install... WTF rivets???
I don't know wtf is going on... I've spent 4-6 hours cumulatively (mostly with the air hammer) and don't have a SINGLE rivet head off. I've tried various things on three different rivets, all to no avail.
So far the only thing that seems to work is a grinder and I'm a little leary of throwing sparks all over the plastic gas tank lol. I do have one rivet head about 50% off (cut off wheel mostly) but can't get to the rest of it with the COW.
WTF?
Using a torch with a cutting tip, I hit the rivet and started to heat it up... IMMEDIATELY all the effin wax starts to smoke and sputter all over the effin place. I get the rivet hot enough and hit the o2 jet: Poof the frame rail bursts into flame lol (all that sputtering wax -- god damn those chevy designers to waxy hell). Crouching in the wheel well, this seemed bad to me especially right next to the gas tank Beat that out with my glove and kept at it a bit. The stupid rivet isn't even scarred...
These rivets ARE carbon steel aren't they? Did chevy switch to hafnium carbide or something?
How the hell did you guys get them out? Grinder?
WTF?
when i did mine on my 96 model i used an air hammer with a chisel bit and use a side approach and knocked the head off the rivet. It honestly took me about 20 minutes. I would try the air hammer again, no sparks. you might have to take the gas tank out to get to the inside of the frame to install the bolts in the new hanger anyway. good luck
i used the cut off wheel and made several cuts on the rivet head and then used an air hammer to knock the small slivers that were left off. then used the air hammer to knock them out once the head was off.
I used a air hammer to take the heads off then a punch to pop it out. About 30 mins. Try a shorter air hose. The shorter the more power. Make one if you have to. Maybe a V cut air hammer chisel.
