Hanger install... WTF rivets???
Originally Posted by blue 01
I used a air hammer to take the heads off then a punch to pop it out.
I found the easiest way to do mine was to drill them out and then knock the heads off with the air hammer and use a punch to knock the rivet out. The heads knock off easy once they are drilled out. Start with a 1/8" bit and center it as well as you can. Go a little deeper than you need so you can get the bigger bits to drill in deep enough. May as well do them all at once. Then slowly increase the bit size till you are close to the rivet diameter. Have a couple of 1/8" bits around because they will get dull and maybe break off.
Put the stands under the frame and the jack under the axle if you are working off the ground like I did. Anyway you will need to support the axle and be able to move it around a little to get the bolts aligned in the new hanger.
Good luck. It is an long tedious job but you will feel like you accomplished something when you are done.
It took me about 30 minutes per rivet. I took one off with the air hammer but it took almost as long and seemed to be really hard work for the hammer and compressor.
11 Second Truck Club
i did it the hard way.
cut a slot in the head with a cutting disc and a die grinder, then beat the hell out of it with a sharp chissil and a big hammer
it took a while but that's all the tools i had, but it got the job done
Hunt&Fisherator
Originally Posted by Beastofa327
God what am I gettin myself into????, Hey Ben wanna help again probably this Oct.
-the hangers wont be bad Matt. I have already beaten my head on them once... not again. work smarter, not harder LOL
