Help with differentials 2500
I own a 2001 2500 LD 5 speed manual transmission 4x4. I want to know what size is the front differential and what size is the rearend. How can I confirm this? Can I measure something? Any help is appreciated.
![Cool](https://www.performancetrucks.net/forums/images/icons/icon6.gif)
The specs I have are for a 1500HD,2500LD but with the 4L80E and LQ4. You have the 5 speed so I am not sure if they are the same or not.
Front Diff: AAM925: 235mm Ring Gear, Axle Torque Capacity 6300Nm, Gear Ratio Range 3.42-4.56.
Rear Diff: AAM950: 240mm Ring Gear, Axle Torque Capacity 6800Nm, GAW rating 2700Kg, Gear Ratio Range 2.93-4.88.
calsdad
06-14-2023 11:07 PM
2002_Z28_Six_Speed
10-04-2015 01:34 PM
FlowmasterMufflers
09-11-2015 03:32 PM
