help with hotchkis part #'s
Registered User
??????2004 silverado??????![Bang Head](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_banghead.gif)
what does this fit
front coils 19810048
rear leaf 24910050
came as a tv kit but i cant find these part numbers n e where!
what does this fit
rear leaf 24910050
From what I found in a Hotchkis pamphlet dated '01, they use a 4-digit number. Got anything like that?
If this helps: All apply to 1/2 ton, 1st is on a reg. cab, 2nd spec is on ext. cab
Coils are either:
-1910F ('88-'98) lowers 2"; 2.5"
-1914F('99-up) lowers 2", but 2.25" lower on EC.
Rear leafs:
-2400 ('88-98) RC or 2401 on EC, both net 4" drop.
-2402 ('99-up) RC or 2403 on EC, both net 3 3/4" drop.
Coils are either:
Rear leafs:
Registered User
I dont, it came from a kit TVS. Ill call HKS in am i just thought some one might have info on the #'s I dropped... This forum rocks you guys actually respond, THANKS from the SFV.
Registered User
funny thing is the HKS # 19810048 and leaf 2490050 is longggg>
the rear leafs appear to be correct. The front coils look huge. Stock with load (compressed) measure about 14.5, HKS coil start to coil end are 15.5.
No problem, I try to help when I can. I'm not sure where my original boxes from Hotchkis are, but I think they're at a friends. They were a long time ago. Rear leafs are H-E-A-V-Y!!!
I can't look at parts now, cause they're on truck already.![Happy](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_stretch.gif)
And yes, it helps handling - quite nicely too!
![Driving](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_driving3.gif)
Registered User
ok Hotchkis stated it will work! a better question would be stock short bed step side sngl cab front coil length. The hotchkis measure 16.5 these things look huge I tell ya. The dealer had no info just part #'s. Not to bug out on this but I dont want 2 pull the coils just 2 compare. HELP
Yea the Hotchkis coils look huge, and when you got to put them in you need to be careful with a jack and get some tension on them. I swore they werent going to lower the truck but they did, the coils are closer together and that's what helps with the stiff performance ride.
5.3Caprice
11-07-2015 08:56 PM
Fast86z
08-23-2015 12:35 AM
