help i need a file for an 07+ silverado 6.2 4l80E
Formerly darynC-10/23/10
help i need a file for an 07+ silverado 4l80E
i cant find a file for hp tuners to flash over ..... 07+ trucks dont come with a 4l80e
is there anyway i can manipulate the computer t0 make the 4l80e work in my truck?
if not im going to have to run a 6l80e and im not to happy with that
apparently its not to hard to get working. the new vans still come with 4l80's so you will need to get a tcm with the van info loaded on it. im no tuner so im just passing info on to you. check out this link though and the OP of this post has his truck running with the 4l80e https://www.performancetrucks.net/fo...d.php?t=454364
let me know what you find out because ive already ordered my converter
maybe justin from blackbear will give some insight on this also as he told me he will get it working on my truck
I'm pretty sure the vans don't have 6.2's with 4L80's. The 6L80e TCM is on hi-speed LAN, if it's not hooked up your going to run into alot of communication problems. Whats wrong with the 6L?
I understand that. But if you program it, it still won't be able to control it. The ECM has no way of controlling the transmission. When you ditch the 6L80e you are also ditching the TCM. Your probably going to have to change harnesses and use PCM for a 6.0/4L70e, and then modify from there.
4l70e the 4l70e's come with an ISS like the 4l80e ....if im correct all i need to do is pull the pins for the ISS out of the round plug and pin them to the front of the trans.
