Help identify which 4l80!
Old 12-06-2014 | 02:19 PM
BLKSSLTT's Avatar
formerly turbo4.8 (2014-06-25)
Default Help identify which 4l80!
Picked up an 80e, have to rebuild it and update things. Help me identify what year 80e it is. It is a 6 bolt case but the trans lines are about a foot apart. It says it's a reman unit. Iv got a few pictures on it torn down. Here they are
This was the only spot a check ball wasn't in
And it had this stupid tail on it but already picked up a new shaft and tail for it
Anyone have any idea what year this thing is so I can order the right parts? Or if I need to take any other pictures of anytging
Old 12-06-2014 | 02:52 PM
Tag says 2000 model.
Old 12-06-2014 | 04:40 PM
SumtinCoo's Avatar
Yep is a 2000. The green tag on the side tells you. The first 2 numbers is the year. Mine says 04 so mines a 2004. But my tag is yellow
HomerSimpson (09-05-2022)
Old 12-06-2014 | 05:36 PM
GMCtrk's Avatar
Ive never seen the green tag before, only yellow.
Old 12-06-2014 | 05:54 PM
BLKSSLTT's Avatar
It says it's a reman unit. So could it have been rebuilt
It 2000? I guess in 01 is when they started the 7 bolt case?
Old 12-06-2014 | 06:13 PM
mdwatts11's Avatar
Green tags are GM remanufactured units. I would bet that it was remanufactured in 2000 if it is a 6 bolt case. Probably a 97 or 98 year model.
Old 12-06-2014 | 06:46 PM
BLKSSLTT's Avatar
All inside parts should be 97+ then?
Old 12-07-2014 | 11:20 AM
mdwatts11's Avatar
You got it!
Old 12-08-2014 | 11:54 AM
Jake's Performance's Avatar
FormerVendor
"Should be".
That assumption will give you grief.
Plus there were changes after '97, so not all parts are interchangeable even on 97 up units.
Old 12-08-2014 | 05:54 PM
BLKSSLTT's Avatar
Well she's torn apart is there anything in particular I should look for?
