Help inceasing low end?
Old 10-20-2006 | 10:05 PM
ta2av's Avatar
Bolt ons such as Magnaflow cat back, KNN high flow intake, taylor plug wires, swapped out clutch fan for flex a lite electric fan and a predator programmer.
Old 10-21-2006 | 10:48 AM
1SlowHoe's Avatar
Destroyer of Transmissions
Converter good
Cam Good
If you are positive you are getting a blower later, decide what kind and, then plan your converter and cam around that so you dont have to swap again.
Old 10-21-2006 | 11:02 AM
bluecajun5.3's Avatar
11 Second Truck Club
with a higher stall converter you will lose mpg in the city.
on the hwy you will not b/c the converter will be locked.
Old 10-21-2006 | 01:47 PM
SnakeOiler's Avatar
Originally Posted by ta2av
... want to improve its low end acceleration but can not afford a supercharger right now. Is changing the stock torque converter to a TT3000 a good way to improve take offs ...
A higher stall will do nothing for low end acceleration, but it will improve your take offs.
If you really want low end acceleration, then you need a cam, heads, etc. that will build gobs of torque in the lower RPM range. A higher stall negates the lower RPM range.
zblee
63
06-10-2023 02:25 PM
fctry286
11-22-2015 04:26 PM
YenkoST
08-28-2015 02:42 PM
JordanH
08-08-2015 08:59 PM
OLD BULL
08-01-2015 06:00 PM
Quick Reply: Help inceasing low end?
