Help picking out a 4L60e to last behind my 406/Vortec TBI 1995 4x4
These are my driving habits and style. Pedal to the floor and running hard often into my red line around 5-5500. I will tow some but I'm a pedal to the metal all the time Driver.
It is a fairly bare bones truck but I added my flare with a 400 small block with a hydraulic roller cam, lifters, rockers and ported larger valve Vortec heads. A ported 2"/50mm throttle body with spacer, and 454 BB injectors @ 90lbs running 32 psi a custom chip with long tube headers and a 2 into 1 then back to 2 dual exhaust. Also have adjustable fuel pressure regulator and a 255lph LT1 type fuel pump.
Motor should be making 400-500 ft. lbs of torque maybe 375-400 on horses at the crank.
Thinking I want 2000-2200 stall speed just to launch harder. It has 3.73 gears with 29-30" tall 20" rims and 10-12" wide contact patch on the tires. But the truck is lowered and most always street driven.
I had bought a Trans-Go #2 shift kit and the Corvette servo but never got them in.
It has an additional cooler and a remote filter as well.
Just want to spend the cash 1 time and get 3+ years of driving time. Its not a daily driver either.
I would like to have the 5 pinion planetary that the 4l65e uses for added piece of mind.
Firm crisp shifts are great. I would like the torque converter to lock up around 50 mph., unless I'm into the throttle and especially stay and hold @65-75. It has kind of jumped into and out of 4th lock up a lot, and come out under the lightest pedal pressure.
Who did you use?
Any warranty issues?
Good service?
Any failures?
Thanks,
Rob
Who did you use?
Good service?
Any failures?
Thanks,
Rob
Speed Engineering sells a swap kit and they are a sponser. Other sponsors for trannys also.
KyleW707
07-29-2015 08:17 AM
