Help with rear diff please
The part number between dual piston and single piston is the same.
99-02 have a smaller one than 03-05 rear disc.
In 05 you 3 different options. You had with rear drum, with rear disc, and over a certain GVWR option which was also 4 wheel disc. I believe the over a certian GVRW is the 1500HD model
Custm2500's Rude Friend
Is it 2WD?
Look at the RPO code and see if it is a true SS truck,
Previous owner may have also swapped to rear disc brakes too.
I guarantee it didn't leave the factory that way.
It may also be a slavage title vehicle or a vehicle with a Vin Swap...
I know some one that has a 2001 Silverado at least on paper. has all the corect Vins but its sitting on a 2003 2500 chassis and drivetrain. The vin in the Computer comes back as a 2003 2500 model truck...
Just saying. Guy didn't even know it until I brought it to his attention.
The Vin on the truck states It's a 1500 series with a 5.3L but the engine is clearly a 6.0/4l80e chassis with 10.5 floater in the rear and 8 lugs all the way around. The frame is also the taller/thicker 2500 frame.
Id thought the option for rear disc was with rc only because of the proportioning valve, and the other was drum or disc.... And yeah the over gvwr was hd... Speaking of proportioning valves..... Do all the rear drum trucks have one or is it just the rcsb and tahoe.... Those seem to be the only models ive seen them on is the short wheel base models
I don't have a tahoe to look at. and the 2 RC's I have had, I did not see it although 1 was a 2500 and both were long beds.
Never seen it on the extended cab or crew cab, and from what I am told it has something to do with a pressure sensor it's not actually a proportioning valve.
And then there is always the swap's too.
Just saying... You might have to do some digging...
When it's in, Id the computer with your scanner and see if
1. The Vin matches the exterior vins on the truck
2. The OS is correct for the vin number. Look here https://tis2web.service.gm.com/tis2web
