help with shift linkage cable
Old 07-14-2012, 07:19 PM
5.3 GMC's Avatar
Default help with shift linkage cable
Tryin to finish my 4l80 swap and my shift linkage cable is to long. How can I shorten it up some?
Old 07-14-2012, 09:29 PM
11 Second Club
brent1976's Avatar
I'm not sure if this is what you're talking about, but there is an adjuster in the cable somewhere down by the transmission.
Old 07-14-2012, 09:44 PM
Vince B's Avatar
Are you using the 4l80e cable to case bracket?
Old 07-14-2012, 09:48 PM
11 Second Hall Moniter
AKlowriderZ71's Avatar
You'll use the original cable, unmodified. You need the bracket for the 80E. There's a GM part number listed in the stickied conversion thread.
Old 07-14-2012, 10:23 PM
5.3 GMC's Avatar
I have the 80 shifter bracket.
Old 07-14-2012, 10:59 PM
Vince B's Avatar
The linkage arm is that from your old 60E? I could see you having to adjust the cable some but it should not be way off.
Old 07-15-2012, 12:56 PM
5.3 GMC's Avatar
Yes its from the old 60. I can force it on but it bows real bad and when u get in the truck u just barely touch the drive select lever and it shoots down in 3. Also it won't go back in park using the lever and I can't get it down to 1 with the lever.
Old 07-15-2012, 01:16 PM
ltr450ryder's Avatar
U mit need a new cable like I did
Old 07-15-2012, 01:28 PM
Can you post a pic of your shifter linkage/cable end? So we can make a suggestion?
I've done a couple of these, and used the truck's original cable without any trouble.
Old 07-15-2012, 01:53 PM
5.3 GMC's Avatar
I'll take a pic of it when I get over there and try to get it up so u can see.
Quick Reply: help with shift linkage cable
