Help! transmission removal problem
I feel like a dipshit but I can't get the transmission to separate from the engine. I spent quite some time making sure I disconnected everything and removed all the bolts. I can get some separation (about 1/4") on the bottom but the top wants to stay together. It looks like the bellhousing is getting hung up on the top stud on the driver's side. I have the truck up on ramps up front and the rear tires on concrete. Should I jack the rear up so it sits level? I'm about to pull my hair out, this shouldn't be difficult.
You must have missed a bolt or stud on the top. Is there a trans dipstick tube or vent tube still resting on one of the studs? If so you will need to move it aside and remove that stud.
Im pretty sure I got them. there should be three studs on top right? Maybe I was tired and missed something. Could have sworn I got everything but that's usually when the obvious bites you in the *** LOL.
thanks for your help
I removed the nut off the stud which had some stuff bracketed on it. It looked as though the trans should slide off it. I'll take another look after I take my daughter to day care.
I just pulled mine and thought the same thing. There is a nut and bolt tdc of trans that holds the vent tube. Make sure you got it. Best way is let the tranny off the cross member and let it droop. Then take about a 4 ft extension and socket and run it straight up the top of the tranny from the tailshaft side...worked on my 4l65e
Well, guess what? ................
I am officially a dipshit!
I guess the nuts I took off on top actually held some brackets and the protruding studs were still bolting the bellhousing in. I think it was too dark and I was too tired to see how obvious this was. the trans is out and the vette servo is in , nex the torque converter and shift kit.
Anyone have some advice on how to get the backets back on the studs?
Sorry for the stupid post and I appreciate everyone's insight.
Hey, **** happens and your thread may help the next guy.
Getting all that crap back on goes best with a case of beer, a little patience and a friend to hold the flashlight. Other then that I don't know any tricks.
