In here....
Moderately Differentiated
Originally Posted by 12sec.5.3
I gotcha. Hopefully this will cure my problem.
Not to throw in wrench of an idea...KANO seems to have it down...but I lost 3 pumps on my 60e before I finally took it to a trans shop that deals with high HP alot and he found that I actually threw my throwout bearing. Nothing was banging around in bottom end yet...but was throwing a/c belts and loosing pumps. If you run into the same problem keep that in mind. It is supposedly unheard of in the automatic transmissions, but happened to me. Good Luck. I am definitely trans dumb and never claim to know alot about them, but my wallet sure hurt after that experience of listening to converter and flexplate ideas.
Originally Posted by 99Silver5.3
Like Kano said. If it has the vac mod kit, that is what adjust line pressure. Nothing else. Shimming the converter is very important. I spent a good amount of timing setting up the spacers on my flexplate. Tight spot didnt make it easy to place them in between there and threading the bolts. I also had to grind a small section off the ends my verter bolts. They were a good bit too long.
I done he same thing
![The Jester](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_jest.gif)
after all that hard work I noticed all three bolts were bottomed out with the spacers spinning freely
![Bang Head](https://www.performancetrucks.net/forums/images/smilies/LS1Tech/gr_banghead.gif)
Another thing I did was take a flat surface like mirror or glass and sanded rhe spacers down until they were exactly the same
I checked the thickness with calipers
rijrunr
10-06-2013 11:59 AM
sprayedenali
07-30-2013 09:54 PM
