Hits rev limiter on 1-2 shift
100% Redneck
There are two different transmission shift tables one "normal" the other called "full throttle shift speed" Are you sure the tuner adjusted the correct table? You can try zeroing out the full throttle upshift MPH tables then the computer will default to the RPM table. If you still have an issue it could be the transmission itself. Is the converter a stock stall or a performance stall converter? I use the free "Bluecat" transmission software for HP Tuners to set up shift points and converter lock up... works very well setting up the shift schedule.
It is stock stall.
Same Tuner did my old trans and it was set up great, I would hope he knows to do as you are suggesting. He is a very reputable tuner here in Southern California.
Additionally, this trans is still under a warranty so I did also consider bringing it back to the shop that installed it.
Thanks again for the suggestions, I’ll try this and go from there. I’ll post my results.
Now, I do have the opportunity to bring it back to the same place I got it since the trans is under warranty so I will be doing so tomorrow.
(I do want to note that the company I bought this aftermarket warranty from is the one who provided the tranny. The shop I’m taking it to has been cordial and is working with me but stated “it’s possible they sent out a bad unit”..)
With all these symptoms any guess on what could be the issue?
It sucks because other than this WOT shift trouble it shifts fine, even if I slowly ease into WOT it shifts 1-2.. it’s only when I push throttle to the floor from a stop.
Truck is at the shop that installed the tranny, I’m nervous they are not 100% sure what they are doing either since after reading some other threads I checked fill level of trans fluid and noticed the shop way overfilled fluid.
Could the overfill cause this shift issue? I have read a few other guys with the 4l60e having this same issue. Fluid was at least an inch over max fill level. See photo.
Overfull not likely to cause it to bang limiter on 1-2
Post the tune and a log if you are able. That will be the best info
the 1-2 shift in a 4l60e is exceptionally easy.
It just brings the band on. The circuit in the VB is not overly complicated and not common to have big leaks.
Band adjustment and condition are important.
Servo type is important.
But the 1-2 is quite simple
@MaroonMonsterLS1 Wish I could post the tune but the tuners shop is about 2hrs away from me.
I have a corvette servo and The sonnax 4th installed.
This problem was happening before and after the servo install.
Hopefully the shop will be able to figure it out today..
