Hotchkis and McGaughy's?
Old 06-23-2005 | 10:49 AM
Default Hotchkis and McGaughy's?
I want to do a 4/6 drop. Everyone says Hotchkis improves your handling. I was thinking that I could use Hotchkis springs and McGaughy's spindles to acheive a 4 inch drop in the front. I would probably just do a flip kit in the rear. Will this work?
P.S.- I plan on running 275/45/20, i think that mcgaughy springs give you 2" where as Hotchkis gives you 2 1/4" on an extended cab
Old 06-23-2005 | 02:12 PM
Last Call's Avatar
TOTM: January 2007
Not sure how well an EC is going to handle. I would use DJM 4" control arms and call it a day. Buy a sway bar if you want the truck to handle better.
The back, flip it. Run some good shocks on all 4 corners and your truck will handle nice.
Old 06-23-2005 | 05:59 PM
Gran Patron's Avatar
Just go with DJM or Mcgaughy's 4/6 kit. Hear tons a good things about them and some minor flaws on both too,but no biggies! A 45 series tire will slightly rub on a 4/6.
Old 06-23-2005 | 07:22 PM
Dub Silverado's Avatar
Dont trust that those springs will give you only two inches of lowering, i put them on my ex cab and it lowered about 3.
Old 06-23-2005 | 10:22 PM
SallyDaGMC's Avatar
I've heard lots of good stuff about Mcgaughy's products, as well as for Hotchkis. Let me know what you go with. I think Mcgaughy's is more pricey though. Anywho I was thinking of using their suspension products, so keep us informed on your decision. Good Luck
Old 06-23-2005 | 10:23 PM
Thanks guys! I think I am leaning towards McGaughy's.
Old 06-23-2005 | 10:33 PM
redaddiction's Avatar
I'm running the hotchiks tvs and I like it.
Old 06-24-2005 | 06:04 AM
tdrumm's Avatar
I already have the Hotchkis 2/4 and when I need new tires, I'm going to get some McGaughy's spindles and shakles and a notch for the rear so I'll be at 4/6.
Old 06-28-2005 | 06:25 PM
McGaughy's. or Belltech I have use both ,but Mcgaughys all the way if i was you. They are both good as for the shocks use Nitro active drop shocks. As for the control arms i personally dont like them because all they do is drop the center cup where the spring sit about 2"and give you clearance problems . For the tires 40s or 35s will only fit on 4/6 and 5/7 drops.
REDCYCLE13
09-15-2016 03:02 PM
06droppedcrew
11-17-2015 10:56 PM
Alco
09-02-2015 04:33 PM
ksbrktracer
08-24-2015 10:55 PM
GMCSIERRA5.3
08-07-2015 01:50 AM
Quick Reply: Hotchkis and McGaughy's?
