Hotchkis springs and chevy lean?
I went through every post I could find about "chevy lean" and was wondering if I replaced the springs, will it solve the problem? I want to get the Hotchkis 2/4 TVS kit. Anyone have the "chevy lean" after putting on new Hotchkis springs? I know if they had the gas tank on the right side, it would help. I know that having the battery, gas tank, and driver on the same side, it would wear out the springs.
Maybe I'll just get somebody like Rosie O'donnel to ride in the passenger side and level it out.
Originally Posted by Tiburon
fon coal spring
I don't think this would totally eliminate the problem. Mine actually leans more in the rear than in the front.
I have considered using a 1 inch coil spacer up front and a 1 inch block spacer in the rear. I have seen the coil spacers for sale, but I'm in the dark about finding a 1 inch block for the rear.
Originally Posted by Snakeoiler
I assume you mean 'front coil spring'. Change it to what?
im putting in some shackles along with my hotchkis that are already on there. i'm dropping the passenger side 2 inches and the drivers side an inch.
so it will "pull back" on the front left side.
I hope it works for you. Let us know if it does.
Yes, my hotchkis kit helped my lean. It still sagged a little with a full tank but was pretty close to level with less gas. I now have helper bags in the back so I just put a little extra air in the driver's side to keep it level.
