How cold is too cold for trans temps
If you are going to block off half of the cooler then use some type of synthetic material, cardboard will break down after getting wet and push into the cooling fins. Go to your on base sheet metal shop if they have one and get a thin piece of Phenolic, its strong, light weight and heat resistant. Just wear a paint mask if you cut it.
