How does a flip kit ride?
Only complaint I have on my 4/6 with a rear flip from DJM is if I put to much weight in the bed my tires will rub, had to roll the fender lips as well for tire clearance but I am running of the shelf 20's, better backspacing with a better wheel would eliminate that. As for the ride a bit firmer than stock but I like it that way so I'm happy with it.
personally i think the belltech flip kit looks like it is much stonger than the other brands, and i think thats the reason its probably more expensive as well.
Originally Posted by skyhighsami
I have a full DJM kit and am very pleased. The only problem I have is with my front shocks. I am going to swap out to stockers tomorrow in the front and see if that helps.
Originally Posted by Nick99Chevy
It'll probably be worse. LCA's need different shocks, especially 4" lca's.
I'm all about people having opinions but don't give somebody the wrong advice man.
Originally Posted by RandomHero
just curious, but do you even have a lowering kit? Do you even know how LCA's work? LCA's don't change ANY part of the coil spring's travel. They're designed to use stock shocks.
No, could you please explain since you know everything?
