how does a stall converter work?
Old 02-02-2007, 07:49 PM
Mr. Obvious
nightrunner's Avatar
Default how does a stall converter work?
reading all these threads about stalls has me wondering how the torque converter works when you get a higher stalled verison
say a 3000rpm stall, does my truck not move until i get to 3000rpm or what?
could someone please give me a detailed explanation of how it works or post a link or something
also would like to know what "flash" means when referring to TCs
i have a vague idea but very unclear on most parts of it
and how can a 3k stall be DD-able
Old 02-02-2007, 07:57 PM
CHEVRACER83's Avatar
FLASH IS PRETTY MUCH IF YOU HOLD THE BRAKE AND NAIL IT.... THE RPM IT WILL HOOK UP AT..... THE STALL OF A TC WILL ACTUALLY CHANGE DEPENDING ON THE MOTOR AND THE TQ IT MAKES..... IT COULD STALL EARLIER OR LATER THAN ITS RATED AT.
HERES A GOOD DETAILED EXPLANATION
Old 02-02-2007, 09:45 PM
Import Moderator
beastmode's Avatar
that is an excellent reference
i too am skeptical about the 3k stall as are others on here but ive had responses sayin to go wit the 3k from ppl who do use them as DDs... i guess ill just have to buy it and test it out
Old 02-02-2007, 09:51 PM
Un-Registered User
mcfarlnd's Avatar
the yank 3000feel almost stock...... when your not in the gas
Old 02-02-2007, 10:08 PM
Import Moderator
beastmode's Avatar
i just dont wanna buy this thing and be like drivin outta my housing plan which is 15mph speed limit so your creapin and have to be ridin at 3k rpms to get out
Old 02-03-2007, 02:46 AM
jblack6527's Avatar
It might rev a little higher, but it won't rev to 3000... unless you have it floored...
Old 02-03-2007, 09:49 AM
2nd fastest 5.3 ECSB
trever1t's Avatar
Yanks are 'tight" . If yo have a TT3000 installed and are on level ground, when you go from park to "D" and release the brake you will start rollimg-like normal.
You can be cruising along at 15mph at 2000 rpm or less but your TC is slipping, ok? When you nail it, it will spin right up to ~3000 rpms and you'll move!
I would suggest a large aux. trans cooler, I run the largest B&M and my temps stay nice and low.
I was concerned too before I got my first stall.
Old 02-03-2007, 11:19 AM
onebadrubi's Avatar
I run a very loose 2800. That doesnt mean it takes 2800 rpms to move my truck. I dont remember about my stock converter but mine will start pullin ghte truck for around town at close to 1500rpms.
Going from stock to 3000 you will loose a little bit maybe 1-2 mpg in the city
Old 02-03-2007, 01:41 PM
Import Moderator
beastmode's Avatar
yea 1-2 is that bad really
so def get a trans cooler (Noted)
Old 02-03-2007, 02:04 PM
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
DD'ed a 3900 for 3-4 months and it wasnt bad at all, I have had 4 stalls ranging from 2800 to 3900 and IMO a 3K-3200 is a perfect compromise. I have also driven many other trucks with stalls, and I like the way the Fuddle converters and the Yanks act. Never driven a PI equipped truck though.
Quick Reply: how does a stall converter work?
