how to install tranny cooler
Old 11-05-2006 | 12:17 PM
dry_kill's Avatar
Default how to install tranny cooler
i just got my yank 3000 installed yesterday and now i need to put my cooler in so i can try to make my tranny last as long as possible, but im kind of confused as to instal it, can someone shed some light on this situation for me, this is the one i bought,
http://www.bulkpart.com/Merchant2/me...roduct_Count=4
thx fellas
Old 11-05-2006 | 12:36 PM
adam1803's Avatar
its really pretty simple, just mount it where the air will flow through it well. Then cut your stock return line from the cooler in the radiator, run rubber transmission line from each end that you cut to either side of the cooler. Basically as long as the fluid flows through the cooler your good-to-go.
Old 11-05-2006 | 12:58 PM
BlackGMC's Avatar
Resident Retard
My truck did not have a factory cooler on it, so I had to start from scratch. i did the typical mounting on the A-Frame in front of the consedor. I wanted to keep the quick-disconnect fiiting on the radiator so I went to Oreillys and bought a quick disconnect fitting for Fuel lines. I had to cut it down a little bit but it fit and no leaks to date.
Old 11-05-2006 | 01:07 PM
dry_kill's Avatar
I have an 06 truck, so which line on the tranny is the supply and return line? There's one on top and one on the bottom
Old 11-05-2006 | 01:51 PM
BlackGMC's Avatar
Resident Retard
assuming that your truck is like an 04, you tap into the top line
Old 11-05-2006 | 02:36 PM
dry_kill's Avatar
ok, so what do i do about the stock top line? do i just use on of the brass nozzles to screw it in there?
Old 11-05-2006 | 02:44 PM
dry_kill's Avatar
maybe if anybody has any pics of the install that would be good
Old 11-05-2006 | 02:57 PM
BlackGMC's Avatar
Resident Retard
You can do that our do like I did and go get a fuel line with a quick disconnet end on it. The line attached to the radiator is the fuel line I pick up, or you can unscrew the fitting like mentioned and use the fitting that came with the kit.
Old 11-05-2006 | 05:21 PM
FLT's Avatar
FLT
FormerVendor
That is how I would do it or just cut the line so you can do exactly what this member has done by using the factory line. Just make sure to always flare the ends that you cut. This will give you a little barb on the end of the line that you cut to help aid the hose clamp and hose from blowing off. Super idea by getting the fuel line by the way BlackGMC! Nice and clean.Vince
Dry Kill just make sure that you are tapping into the top cooler line coming from your transmission. This is the return line to the trans.
Old 11-05-2006 | 09:45 PM
dry_kill's Avatar
so is this the basic concept im looking for? sorry for the poor pic, made it on paint, lol man it looks bad
