How much gear to offset 4l80 install?
Originally Posted by slowec
I currently run 3.42's. If I install a 4l80, How much of gear in the rear will I need to change to in order to achieve the same 1st gear ratio? Thanks in advance . I am sure somebody knows
How do I change this text
might want to check out 3.73. most Turbo guys run or wished they ran 3.73 over the 4.10, but one other thing you didn't say, how big of a tire are you running?
Mr. Obvious
Banned
1 Post
Originally Posted by quicksilverado
Keep the gears you have they will make the turbo spool. If you swap to 3.73 or 4.10s it may slow down the spool.
same thing i was thinking if anything put a 50hp shot for the hole shot but a turbo likes back pressure,bind on the motor and that will net a better et check out wildracing z71 excab stock motor trans verter ran 11.4x i think he has 3.42 if i remember right
LCHEE
10-24-2020 04:10 PM
