How much play should front end have...
04 Tahoe.. has a shake in the front end. Tires rebalanced, still shaking. Checking tie rods, idler next. With one front tire off the ground, how much play should be there.... ie how much should the wheel move. I can move mine considerably...
side to side movement will indicate a bad tie rod, put one hand on top of tire, and the other under it, push in with one, pull with the other, if it moves, is a bearing, you shouldnt have any movement
11 Second Hall Moniter
Even though those parts are worn out(according to your description of movement), replacing those probably won't correct a vibration problem. If your vibration begins between 40-45 mph, and changes with vehicle speed, then it is related to the tires & wheels. You may have an out-of-round tire, bent wheel, corrosion on the hub/rotor flange, or maybe the guy balancing your tires messed up.
If you are experiencing 'death wobble', which can happen at low speeds or high speeds, it is often caused by worn out pitman and idler arms. DW usually starts(or is aggrivated) by bumps in the road, then applying the brakes or completely stopping the vehicle will make it stop....until the next bump.....
If the components have been worn out long enough, you may have badly worn(choppy tread) causing the vibration.
Ask your front end mechanic to DIAGNOSE your vibration.
5.3Caprice
11-07-2015 08:56 PM
Offroadunleashed
07-20-2015 02:25 PM
