How to prevent this.....
#22
11 sec. Truck Mod
How much Rwtq are you making ?
My Previous 07' Duramax CCSB weighed 7000 lbs and made 800++ rwtq with the stock alum drive shaft , no probs what so ever even with lift blocks .
You may want to get rid of the coils and do a conventional leaf spring setup with traction bars .
FWIW I use a 3.5 " steel shaft in my silvy , I know it's shorter than what you need but I would like said above check into if it would be a better option for you .
#23
#26
11 sec. Truck Mod
I am just trying to offer another view / solution to the problem .
I'm not saying a linked suspension won't work or that they are bad , you are misunderstanding my post.
His stock rear setup isn't working , so either it needs upgraded with better parts or he could swap in a rear leaf setup fairly easily and in expensively , it's up to him .
But my leaf spring setup sucks , it only cuts 1.60s so far
#28
I was advised long ago by Inland Empire Driveline that the power I was putting down with the Tahoe back in the day was better served by a steel shaft. We went with a fixed yoke on the Gear Vendors output shaft and a splined steel shaft with solid 1350 joints in between. That configuration eliminates slipyoke binding on the tailshaft and has been bullet-proof through all motor configurations. I went with the same setup on the Suburban.
Honestly, it should be breaking axle shafts or ring gears before breaking the driveline.
