How to prevent this.....
#31
#32
11 Second Hall Moniter
Dr X, are your stock control arms boxed? Have the bushings all been replaced with polyurethane or polygraphite pieces? If not, that's where I would start. With your power to weight ratio, and traction with slicks, you are getting a ton of deflection in all of these parts.
And for the same reasons, I also agree with the other posters here about u-bolt yokes instead of strap style, and a fixed yoke on the trans.
#33
Received these today:
#36
"I don't see any benefit in going to a bolt on yoke and then a heavy 4 inch steel shaft with a spline stub and slip either.The 5.0 Alum has more torque rating than the 4.0 steel. I don't remember your gear ration but if deep gears critical speed could be an issue also."
I believe critical speed for the Al was around 7000, not that it would get that high at the track in 3rd. Looks like I was trapping around 5500, which I think is about where the CS was for 4" steel.
