How to test Truetrac
Old 07-06-2012 | 10:24 AM
  #21
1CLNY2K's Avatar
Yeah my true trac lights em both up everytime no matter conditions. Can be tricky making tight turns as the locking action tends to push the front end a little bit. With mine being a 5 speed it really chirps going up steep turns when i let the clutch out in first.
Old 07-06-2012 | 10:29 AM
  #22
nonnieselman's Avatar
sounds like it works to me..
now find a ditch or uneven terrain and go across it where you only have one front tire and one rear tire touching... if you make it out, it works..
My Eaton LSD works with only one rear tire on the ground. Actually happens more times than you would think
Old 07-06-2012 | 10:30 AM
  #23
TXsilverado's Avatar
both tires on pavement. keep your left foot on the brake and stand on the gas for 3-5 seconds. why is this so hard to grasp?
Old 07-06-2012 | 10:33 AM
  #24
Originally Posted by Ferocity02
So I tested it on the way home. Found some road where I could put the right tire in sand/dirt and the left tire on pavement. I then punched it from a stop and the left tire was chirping on the pavement as it struggled to get traction. The right tire spun enough to kick up dust, but the revs stayed low and neither tire seemed to actually break loose. I feel like this was a positive result.
He did...
Old 07-06-2012 | 10:34 AM
  #25
he was half sand and half pavement and aparently is afraid to make some noise. fire those bitches up!
Old 07-06-2012 | 10:42 AM
  #26
2-3 minutes.. right?
gotta make sure it holds
Old 07-06-2012 | 11:16 AM
  #27
Chevy_King1500's Avatar
this ^^^
Old 07-06-2012 | 11:47 AM
  #28
2 tone 02's Avatar
Heres an old truetrac video...
Testing out Truetrac
Do this!
Old 07-06-2012 | 11:54 AM
  #29
weak sause!
Old 07-06-2012 | 11:57 AM
  #30
MPFD's Avatar
11 Second Truck Club
How do you make 6000 posts, do you own diff work and not understand how a posi works?
