How would you achieve a 4/6 drop?
Old 01-17-2013 | 06:04 AM
  #21
shorty's garage's Avatar
My djm notch fit good and spindles+springs won't change your geometry as much as control arms.
Old 01-17-2013 | 06:12 AM
  #22
texasglock23's Avatar
Sure the notch fits...but they also fail causing the frame to buckle and crack.
Old 02-17-2013 | 12:43 PM
  #23
bs4.8's Avatar
im using mcg 16" 2" drop spindles,2" ground force coils up front,rear is the new style djm flip kit..throw away their notch though,buy a belltech or mcg ..djm I guess bend..I havent personally had issues with thedjm notch cause I read up first before buying anything,but after having the nnotch in my hands I wouldn't use it..its just a plate with a c welded to it,and the c is welded on the front,if you flip it over you can see the 1/4" gap between the c and plate that's not welded up.I have run djm spindles,sways,coils on ton of trucks with zero issues but their notch looks very weak
Old 02-18-2013 | 05:10 PM
  #24
If you get the DJM notch, just bolt it in, then have it welded up, that should be more than sufficient, but I would spend my money elsewhere.
BROKE-aSS-BLAZER
10-13-2017 04:50 PM
Chewy07
11-14-2015 10:46 PM
vmaxpro
09-28-2015 12:10 PM
twake_410
09-25-2015 11:09 PM
pewter00
09-11-2015 10:32 AM
Quick Reply: How would you achieve a 4/6 drop?
