HPTuners Shift Pressure Values?
Old 08-20-2015 | 10:50 AM
therock's Avatar
Default HPTuners Shift Pressure Values?
Just curious. I don't mess around in there on my own.
I have been comparing tune files and see in one instant the numbers changed in Brake Shift Pressure from 90 to 96.
In the other tables they are all increased by 4.
I think I read the lower the value the higher the pressure but I wanted to ask you guys.
Just curious? Which way does it go?
Thanks
Old 08-20-2015 | 11:10 AM
madmann26's Avatar
Thanks
Higher number = more pressure
Lower number = less pressure
Old 08-20-2015 | 11:32 AM
03sierraslt's Avatar
Also know that the values in that table mean nothing without comparing the force motor table as they work together. That's not counting all the adder tables.
Old 08-20-2015 | 12:09 PM
therock's Avatar
Thanks, that's why I don't mess around there. I was just doing compares and wondering.
Old 08-20-2015 | 03:31 PM
Atomic's Avatar
I have a gauge for that
That table is actually the column lookup table for the Force Motor Current (FMC) table. You can increase the values in that table that moves you over a column in the FMC table, or you could just change the values in the FMC table directly. The values in the FMC table are miliamps to the shift pressure relief valve (forgot the actual name) in the trans, so the more current the more the RELIEF valve opens. That's an easy way to remember the lower the value the less relief so the harder the shift.
blownss27
08-14-2020 09:27 AM
Go5.3tt06
25
09-04-2016 11:25 AM
jtphelps289
09-29-2015 01:00 PM
mayko
09-07-2015 01:24 PM
