Hub Wheel Assembly?
Mr. Obvious
thr rotor has to come off and the caliper mounting bracket does too. you can just lay the caliper up out of the way but it does have to be unmounted, but you dont have to disconnect the brake lines. you will need a large Torx bit, about a T45 or so, cant remember, its for the caliper bolts
disconnect the wheel speed sensor on the back of the hub
then unbolt the old hub from the spindle
reuse all of the old bolts.
i have had to replace 5 left ones and about to be the third right ones. it started at about 35k and i have 114k now. 2 in. drop spindles and 18 x 9 wheels, one went before wheels , two after wheels, and the rest after drop. mine seem to be loosing the back seal cover and gettng dirty.
Only available new through either off-road company...
http://www.camburg.com/
http://www.blitzkriegoffroad.com/
Not cheap but guys are running 37" tall tires in the dezert beating them to hell so I'm sure they would last a long while if not the life of the truck on a daily driver.
SlvrSierra4.8
10-01-2015 09:39 PM
