Hvyweight/Lightweight Vehicle Stall
Old 10-24-2008 | 01:32 AM
A Low Dime's Avatar
13 Second Truck Club
Default Hvyweight/Lightweight Vehicle Stall
Ive talked to several different people about this and nobody is quite certain which would be correct. Ive noticed that most cammed LSx truck guys run 3000-3600 stall.
Now my truck should only weigh about 3300lbs. with me in it. What size stall would be better for me. Since it ways less should it be a 242600ish stall or the opposite 4000 stall?
There will eventually be more mods for the truck, but would a stall make a good enough difference for me to actually do it?
Old 10-24-2008 | 01:42 AM
95 bright teal's Avatar
Stall is similar at most weight, you want to find a stall that will keep your motor where it makes power, if your not making power until your above 5500rpms you want a bigger stall.
most of us are making most of our power from 3000rpms up, so the stall gets the truck to those rpms
Old 10-24-2008 | 01:46 AM
A Low Dime's Avatar
Well if that is the case than the 4.3 doesnt need a stall as it quits making power most of the time above 5000RPM's anyways?
Old 10-24-2008 | 01:52 AM
The point of the stall is to keep you where you make power
The guys you see on here with 3000+ stalls have larger cams that are a little sluggish below 3000rpms
for your truck unless you put a big cam in it i would not worry about it
Old 10-24-2008 | 01:53 AM
A Low Dime's Avatar
Old 10-24-2008 | 01:58 AM
So if you are going the cam route, find out where the cam will make power, and choose a stall accordingly.
so what do you have planned?
Old 10-24-2008 | 02:02 AM
A Low Dime's Avatar
What ever makes me run faster. Only things I can think of that are left for the 4.3 is, headers, larger Y pipe (stock one is 1.75"), ported heads, 266 or 270AHR cam, maybe a stall, MPFI marine intake.
I cant think of any of bolt on's at the moment.
Then nitrous or boost.
Old 10-24-2008 | 10:33 AM
silver-mod-o's Avatar
Hunt&Fisherator
You are going to need a higher rated converter to see the same stall speed as a FS truck... Stall speed is directly affected by vehicle weight, engine tq, and how the converter itself multiplies torque... The heavier and/or more powerful a vehicle is, the higher the converter will flash/stall to... My SS3600 in my sig flashed to ~3400 N/A, and in the same vehicle same motor, with just the addition of the turbo (considerably more tq) it will flash to over 4400...
In an S-10 I wouldn't want anything bigger than a 9.5in converter and something with a 3400 or larger stall speed depending on cam choice... Gear selection will change it slightly as well but it will be hardly noticeable in a light truck like yours... Hope this helps some.
Old 10-24-2008 | 10:36 AM
BlackGMC's Avatar
Resident Retard
hmmm, that converter is going to be expensive.... A 9.5 @ 3200+ is like 600-1000.... Motor swap maybe a better option....
Old 10-24-2008 | 11:46 AM
built408's Avatar
Just match your converter to the new cam. You won't need a higher stall just because yours is lighter, you will just need one matched to your power level and your weight. I know those v'6s make most of there power and torque mid range. So a 2800- 3000 converter would probably work best.
blowngmc
32
10-12-2017 12:59 PM
Blwn99x
09-11-2015 10:27 PM
06 4.8
09-11-2015 11:36 AM
custm2500
09-08-2015 06:53 PM
chvy=power
09-08-2015 11:59 AM
