hydroboost
i just swapped over and love it!!!!
can leave off the line now on 8-10# boost!!!!
1 thing thou...i have to start the truck in neutral...not in park cause i cant move the shifter outta park...there was a connector on the vac boost that didnt have a place to go and also a connector on the brake peddal itself...anybody got any insite on this...2004 excab...
The connector out front is for the vacuum assist motor. I got a service brake in the message center until I jumpered it out. The switch on the brake pedal is for your brake lights I assume. It should be plugged up and suspect that is why you cant start in park. Do your brake lights work?
i have not got a service brakes message or any other message for that matter but my brake pedal does stick up as hi as it can go and just found out this morning my brakes are dragging a lil so what would i need to do to correct this issue...space out the master cylinder or what
the connector for the pedal wont even fit the way it is right now...after reading some more it looks like im gonna have to make the 10mm plate because the rod is to long..just my damn luck!!!
i'll get it in 2 weeks when i come in from work.
GMCtrk
18
10-06-2015 03:48 PM
mrgrim
07-08-2015 08:12 AM
