Hydroboost Conversion, how to with pics
Old 03-06-2012, 02:06 PM
  #61
01silvy's Avatar
Appreciate it, ill pick one up..
Btw Atomic, thanks for doing this thread.. thanks to you my hydroboost swap went great and my brakes feel amazing now!
Old 03-06-2012, 02:09 PM
  #62
I have a gauge for that
Atomic's Avatar
no prob
Old 04-16-2012, 03:33 PM
  #63
Charlie Murphy!
iregret's Avatar
Just FYI, I'm in the middle of doing this swap right now. It says in this thread that you can use your stock master cylinder. My truck is a 2000 Silverado 4x4. My master cylinder definitely looks different than the one pictured in this thread. I took my hydroboost and master cylinder from a 2003 Escalade. Check out the difference.
I'm going to be swapping the master cylinders as well. I'm not sure why my truck has such a small master cylinder in comparison to the hydroboost one.
I just wanted to point out that the diameter of the master cylinder itself is the same, but the length is different. (obviously) So, I suppose one could use the smaller factory one. I'm not sure why the truck needs such a large reservoir of brake fluid.
Old 04-16-2012, 03:38 PM
  #64
Atomic's Avatar
Not sure if the esacalade has rear drums or disc but drum brakes usually require a greater volume of fluid.
Old 04-16-2012, 03:43 PM
  #65
Charlie Murphy!
iregret's Avatar
The escalade had rear dual piston calipers.
It might just be a early model year thing. My 2000 has 4 wheel disc brakes.
One other thing, my brake lines to the master cylinder are bent differently as well. I think I'm going to be able to make it work though.
Old 04-16-2012, 04:51 PM
  #66
Charlie Murphy!
iregret's Avatar
Something else I want to add. I've been contorting myself in all sorts of weirdo positions in an effort to get to the vacuum booster and brake pedal bolts. It turns out, you can see these bolts pretty clearly through if you remove the fuse panel cover and look past the fuse block.
This is the best picture I could get. See the ratchet back there?
Old 04-17-2012, 09:43 PM
  #67
Charlie Murphy!
iregret's Avatar
I just finished the install with the help of this guide. I didn't feel like taking the power steering pump off. I figured if I'm going to be taking it off, I may as well swap on the proper power steering pump.
I managed to get the high pressure line off by removing the front air dam and using a crowfoot attachment.
Like this:
Thanks for the write up Atomic. I really appreciate it.
Old 04-17-2012, 10:51 PM
  #68
Atomic's Avatar
Glad you found it useful
Old 04-18-2012, 12:01 AM
  #69
graysilverado5.3's Avatar
Write up helped me when I did the conversion also, along with the fuel pump write up, lol. I also took of the panels and didnt have much trouble taking off the bolts.
Old 05-08-2012, 04:39 PM
  #70
banker099's Avatar
anyone else have to cut the firewall to get the booster to fit flush on the firewall?
looks like im going to have to cut the top part of the hole to make mine fit
Quick Reply: Hydroboost Conversion, how to with pics
