Hydroboost Conversion Install
Old 12-12-2008, 06:30 PM
  #91
nonnieselman's Avatar
come to think of it.. yea you got it backwards..
Old 12-12-2008, 06:35 PM
  #92
i think that line goes from the Driverside of the booster to the steering box?
I can tell you for sure tomorrow.. im not around my truck at the moment.
Old 12-12-2008, 06:37 PM
  #93
Coban's Avatar
Yep, On the booster side, the line has 2 90 bends and then goes to the steering box. That's the way I'm trying to run it and thats the way my dads truck has it.
Old 12-12-2008, 06:40 PM
  #94
Im thinking you have the wrong hose?
you can try to bend it slightly.. dont crimp it or your in trouble..
Old 12-12-2008, 07:00 PM
  #95
Coban's Avatar
I just got the one from the Caddy's now. Gonna pick it up in the morning.
Different part number, so it could be the one im looking for.
Thanks for the help.
Old 12-12-2008, 07:56 PM
  #96
Coban's Avatar
Problem #2: The pedal sticks out waaayyy too far. I must be missing something.
Old 12-12-2008, 08:04 PM
  #97
howard quick's Avatar
Sometimes the hydroboosted vehicles use a different pedal to the vac brake vehicles.
You may need to get that pedal.
Does the rod connect to the pedal in a straight line?
Old 12-12-2008, 10:03 PM
  #98
Coban's Avatar
I did get the new pedal. The post is in the correct spot, at least its different than my stock one.
Old 12-12-2008, 11:03 PM
  #99
Some of the hydroboost rods are different lengths also.
It's almost impossible to shorten them without destroying the HB unit.
Old 12-13-2008, 08:06 AM
  #100
KySilverado's Avatar
The rod in your booster does appear to be longer than the one I installed. Mine had the offset bolt pattern
Quick Reply: Hydroboost Conversion Install
