Hydroboost Conversion Install
Old 04-10-2009, 11:23 PM
  #121
Coban's Avatar
Yea, I've never seen that motor thing. That brake pedal looks different actually. Not saying it won't work, but it looks like it might offset the pedal if it does work. The bushing at the top of my pedal formed a "T". That ones offset.
I used the same hydroboost unit though. --With the big accumulator cylinder. No idea why its bigger.
Good deal on the hoses though. I can't see all of them, let us know how they fit up. The only one you will possibly have problems with is the one that goes from the HB unit to the steering rack.
Old 04-11-2009, 01:32 AM
  #122
I have a gauge for that
Atomic's Avatar
I had to rip out the entire steering column of the tahoe to get that pedal out, it better work!
Old 04-11-2009, 06:34 AM
  #123
KySilverado's Avatar
I've never seen that pedal before either. Is it one of the options that will adjust the height of the pedal assemblies?
Old 04-11-2009, 11:20 AM
  #124
Atomic's Avatar
I was out of a 2006 LT tahoe loaded with sunroof, airride, and probably leather (the seats were gone). Im thinking I might just need to find another pedal, but man was this thing a pain to take out.
Old 04-11-2009, 05:33 PM
  #125
MikeGyver's Avatar
I think it's for the cops, they can put your brakes on by remote control. Not to arrest you, but just so they can watch some cool wrecks.
Old 04-11-2009, 07:30 PM
  #126
Coban's Avatar
Ah, smart man. That's probably what it is.
Old 04-11-2009, 07:37 PM
  #127
howard quick's Avatar
Either that or possible for braking whilst going down steep hills in 'Cruise Control'.
Old 04-11-2009, 08:16 PM
  #128
BlownHD's Avatar
Wow, just read through this whole thread and learned a ton about the hydroboost system. My truck came with one, but I never thought anything of it. Now I know why the pedal on my truck is so firm and responsive compared to my parents 03 z71 suburban. I kind of want to do the conversion for them as sometimes they complain about the brake pedal.
On another note, one thing to watch is your PS fluid level. Just recently I had the pedal go to the floor on me twice while maneuvering in a parking lot, it would stop the truck, but I had the pedal all the way down. As soon as I started moving and wasn't working the wheel back and forth the pedal pressure came back to super firm. I checked the fluid and it was a little low, at the full cold mark while hot. Apparently it was just enough to get some air in the system and have the pedal loose pressure.
Just something to watch out for
Old 04-11-2009, 08:23 PM
  #129
Atomic's Avatar
So you think I would be better off with just a normal pedal? Go figure I spend an hour trying to get this one out and its not even what I need.
Old 04-11-2009, 08:33 PM
  #130
Only issue with a normal pedal is...you may need to make either a thicker mounting plate or an adjustable pedal rod/linkage.
Quick Reply: Hydroboost Conversion Install
