Hydroboost Conversion Install
Old 05-15-2009, 01:38 PM
  #171
I have a gauge for that
Atomic's Avatar
Is it suppose to be broken at the top of the piston hole (right below the actuator) like that?
I have a feeling no...
Old 05-15-2009, 03:06 PM
  #172
2001CamaroGuy's Avatar
Yes, that is a factory cut for the linkage. You booster looks fine to me. Just check everything for rust and/or pitting.
Old 05-15-2009, 03:38 PM
  #173
Atomic's Avatar
Actually, in that picture the accumulator piston should have popped out, but you can tell its stuck in there.
haha, a couple swift wacks with a screwdriver and it popped right out and now moves freely.
So I now have a spare master cylinder and hydroboost off of a 2005 2500hd if anyone wants to buy one.
I am pretty confident that was the problem, but I have to install it back first...(knock on wood).
edit:
Yep, works great, I can lock up the tires at any speed below 60 now, and thats saying something for 35" 115 pound tires.
And to think I spent 3 days trying to figure this out when all it needed was to be hit a couple times.
Old 05-17-2009, 01:58 PM
  #174
Got mine in yesterday and wow does it stop! While I'm obviously getting higher (brake) line pressure (the truck stops harder/faster), the pedal pressure seems higher/stiffer. It feels more like a manual brake pedal. Is this typical/something to get used to?
Old 05-17-2009, 02:28 PM
  #175
howard quick's Avatar
Yep....sounds typical. The firmer pedal is deffinately something to get used to.
Old 05-23-2009, 02:59 PM
  #176
Atomic's Avatar
Will a booster off of an 05 2500hd fit on an OBS 99 tahoe?
Old 05-31-2009, 05:34 PM
  #177
Pics reposted!
Old 07-01-2009, 09:03 PM
  #178
2004SSS's Avatar
just wondering why some of you changed your master cylinder? i dont know if the ss truck differ but mine bolted right up and wasnt angled or anything , i had the hd one to use but opted to keep mine because it had a larger reservoir.
Old 07-01-2009, 09:43 PM
  #179
EVILGMC's Avatar
hmm....im doing my conversion later this month...will have to see if my master cylinder will work.
Old 07-01-2009, 10:55 PM
  #180
If you note my post, I stated I also reused the stock (vacuum) master cylinder when I did my hyrdroboost conversion. It not only saved me the effort of bleeding the brakes, but also saved me a bit of money since I was able to return the unused HD master. Been working beautifully now for over a month/5K miles.
54inches (01-09-2023)
Quick Reply: Hydroboost Conversion Install
