Hydroboost Conversion Install
Old 11-08-2011, 05:13 AM
  #201
GM Power4Life's Avatar
Default Just to be sure...
So if I buy a full factory HB setup including HB, lines, PS pump, HB pedal, and reusing my master cylinder....IT SHOULD ALL BE DIRECT BOLT ON?? Other than drilling one hole for the offset pattern?
Thanks for the advice gentlemen. I know this is an old thread, but due to multiple deployments to Iraq i've been held back from modding my truck. Time to get after it
Old 08-27-2012, 01:31 PM
  #202
fix-it man's Avatar
Want to order the parts for this asap as my power steering pump is on the way out.
After reading the whole thread I'm a little confused. are the angles for the hb pedal and stock pedal the same, and the only difference is where the stud is in them? If so can I drill a new hole and just move the stud on my factory brake pedal?
Also read that some people made a new mounting plate that's 10mm thick, is that to take up the extra space so you can use a stock pedal instead of the hb pedal. I can fabricate things pretty well, so I'm looking at what's my best bet instead of ordering a new brake pedal if I don't have to
Old 08-27-2012, 01:38 PM
  #203
I have a gauge for that
Atomic's Avatar
The pedal is only $30 or so...how much is your time worth?
Old 08-27-2012, 01:46 PM
  #204
fix-it man's Avatar
I have a lot of time lol. I should just order the pedal instead though. I found a complete setup on ebay with booster, master, ps pump, and all the lines for $240 shipped and the same guy has the pedal for $50. do those prices sound about right? or too high
Old 08-27-2012, 01:59 PM
  #205
Atomic's Avatar
Sounds good for the group, but I think you can get the pedal cheaper from an online GM dealer.
Old 08-27-2012, 07:01 PM
  #206
fix-it man's Avatar
Ok I'll check for a pedal, I did order the rest of it though
Old 08-28-2012, 12:24 AM
  #207
RacinRust's Avatar
Contact one of our members. Beau@SDPC. Great guy to deal with. One of the advertises on the right.
Old 02-11-2013, 08:48 PM
  #208
5speedsilverado's Avatar
didn't really find an answer in here, but its fine to do this swap with rear drums?
Old 02-12-2013, 12:01 AM
  #209
Custm2500's Rude Friend
1FastBrick's Avatar
Short answer YES!
Your eliminating the need for a vacuum source for the brake booster to work correctly and making it more reliable by going to a hydraulic assist.
Old 02-12-2013, 11:09 AM
  #210
cool thanks!
Quick Reply: Hydroboost Conversion Install
