i feel so bad for all y'all NNBS guys
Old 04-26-2011 | 04:54 AM
drperry's Avatar
If the bank says yes to the '07 I want, it'll be getting a ZF6...
If they don't... Then I'll be finding a way to shove one into my Blazer
Old 04-26-2011 | 09:04 AM
_zebra's Avatar
makes children cry
is the 07 a HD? if not, be ready to buy a body lift
and why would you put that in a blazer?! it's as big as your blazer!
...unless it's a K5 or 92-94
Old 04-26-2011 | 12:05 PM
drperry's Avatar
I'm prepared to body lift, and cut the trans tunnel
And I was going to put it in my Blazer because the NV3500 can't stand up to my future plans I had for it... Supercharged 6.0 and towing/4x4ing
I don't tow often but when I do it's often over 5000lbs...
My Blazer on its own weighs 4400lbs, which is already over the T56's GVWR, so that would rule out any towing...
Apparently the banks said yes, though, so I'll be getting the '07 2WD today
Old 04-26-2011 | 12:29 PM
bigboy576103's Avatar
Interesting this is the first time i ever heard about this.. i Guess they cant
Old 04-26-2011 | 01:14 PM
black04's Avatar
Auto trans with loose converter ftmfw
Old 04-26-2011 | 02:59 PM
_zebra's Avatar
makes children cry
well you can't use a T56 with a transfer case anyway, but on the weight, there're a couple guys running around with them in suburbans & doing fine. that said - they can't tow & shouldn't haul a lot, but come on, the GTOs are over 4000lb & they used T56s. that's probably why they had Z06 gearing, too
yeah... in a straight line for a few seconds
Old 04-26-2011 | 07:54 PM
drperry's Avatar
The RS Gear (IIRC) T56 for the Sy/Ty's works
That being said... I got my '07 so I don't need to worry about a t-case
Old 04-26-2011 | 07:58 PM
_zebra's Avatar
makes children cry
i might just have to look into that...
the only t56/t-case combo i found a few years ago was one some guy custom-fabbed & it didn't work all that great
Old 04-26-2011 | 08:07 PM
drperry's Avatar
Yessir! However, these look factory...
They just didn't suit my needs.
Old 04-28-2011 | 03:45 PM
_zebra's Avatar
makes children cry
so apparently the Mexicans did, in fact, get some manual NNBS trucks.
they had the M96 & TZ0 transmissions from tremec
well i'll be!!
BKnBLK05
12-28-2015 09:52 PM
Go5.3tt06
09-12-2015 10:29 AM
fillpot
07-26-2015 08:21 PM
GM-only
07-19-2015 11:48 PM
fcompean
07-15-2015 10:55 PM
